nEED help
JRHPHOTO2001
Hi everyone. I have a Canon 450D That will Not Format the SD Card. It prompts me that the card needs to be formatted, but when I try it will Not recognize the card. I tried with all my cards. I even formatted the card with the PC, and with my other cameras. and still nothing. Any advice.
3 REPLIES 3
John_
Try looking inside the card slot for any debris in there that could be preventing a good connection. The contacts inside the card slot may be dirty or damaged. For a test, you can blow inside the cards slot then insert/reinsert the card a few times. If that works then get a good contact cleaner like Deoxit5 and use that to clean them for the long run.
JRHPHOTO2001
Thank you.I will give it a try.
Call Canon 1 (800) 652-2666 It needs service.
