06-23-2016 09:16 PM
Out of no where my EOS Rebel T6 stopped letting me film. i press the recording button and it wont film. its not stuck or anything. got it two weeks ago and a week later this issue began. i read the manual many times and everything is okay in the filming menu. so i dont know whats going on. please help
06-24-2016 07:10 AM
Double-check that the switch is in the Movie postion.
Remove battery and switch camera on; reinstall battery.
In Menu select Clear/Reset camera settings.
If none of those work take it back; its less than a month old and you should get a replacement.
06-24-2016 08:13 AM
Make sure your memory card isn't filled up, too. Re-read the cautions in the instruction manual regarding the potential for excessive heat buildup during extended use in video mode, or Live View mode. If the image sensor begins to overheat, then the camera will basically stop operating until it has cooled.
Some vendors have 15 day return policies, while others have 30 day return policies. In any case, it should still be under warranty with Canon.
06-25-2016 01:49 AM
