07-27-2015 08:37 PM
I bought a t5i less than 6 months ago and now for some reason the mode is not showing on the screen
when changing the different modes. Is there a setting for this ? I can turn the dial however nothing shows on the screen.
Any advice or setting ?
07-27-2015 09:29 PM
12-01-2015 04:14 PM - edited 12-01-2015 04:15 PM
I'm not clear on whether or not your LCD works but simply doesn't have a display indicating which mode you are using -OR- if the LCD screen isn't showing anything at all.
The "Disp." button will cause the camera to cycle through various optional types of info that the LCD screen can display (one of those options is to display nothing at all and the LCD panel will remain dark.)
Try pressing "Disp." (you may need to press it several times... each press changes it to the next selection and when you get to the last option and press it one more time it goes back to the beginning of the list.)
Note that John mentioned pressing the "Info" button. Some cameras have this labeled as an "Info" button and some have it labeled as a "Disp." button, but it works similarly. On your model the button is labeled "Disp.".
