02-17-2016 06:15 PM
02-17-2016 07:19 PM
The 58mm is your filter size (diameter). Both of those lenses use a 58mm filter. So a 58mm filter will fit both lenses.
02-19-2016 01:10 PM
The filter thread diameter is also almost always printed on the inside of the lens cap (since the cap has to grip to the filter threads.)
02-20-2016 11:59 AM
@tatyana-sumakov wrote:
I actually have two questions, but this is part one. I'm looking to get uv filters for my t5 lenses to keep them safe. I'm almost sure that a 58mm uv lens will fit on my canon but I want to double check before I order something on line and it will be a hassle to return. Most for the discriptions say for t4i t5i and so on but doesn't say t5, will a uv filter intended to fit a t5i fit a t5.
I use Sensei Filter Stack Caps to store filters. Check them out online.
These are basically two metal caps that screw onto the front and back of a thread filter, which protects it. You can "stack" a set of lens filters between the caps, which I find provide MUCH better protection than a filter pouch. Plus, it consumes less space than a pouch, and they cost less than a pouch.
Caution, they are easy to over-tighten. Although I have never experienced the problem, once you use them it will quickly see how easy it is to torque them down too far. A large temperature change later, and now you need a lens wrench.
