02-17-2016 06:15 PM
02-17-2016 07:19 PM
The 58mm is your filter size (diameter). Both of those lenses use a 58mm filter. So a 58mm filter will fit both lenses.
02-17-2016 06:33 PM
Sorry, the FD lenses that worked on the T70 will not work* on your T5i. Your camera will work with all EF and EF-S lenses. As for the 58mm filter, it depends on your lens.
* Of course, there are adapters you can get, but it is not worth it.
02-17-2016 06:40 PM
02-17-2016 06:46 PM
Yes, the T5 and T5i will use the same EF-S and EF lenses, but that has nothing to do with the UV filter. We need to know which lens you have.
02-17-2016 06:53 PM
T5 and T5i have the same lens mount. Any lens that fits one will fit the other.
Both can use EF mount lenses and EF-s lenses.
02-17-2016 06:47 PM
The uv filter goes on the end of the lens, not on the camera. Lenses that fit the T5 will also fit the T5i. 58mm is a common filter size.
What lenses do you have? It is a matter of seeing what filter size each lens takes.
02-17-2016 07:05 PM
02-17-2016 07:19 PM
02-17-2016 07:23 PM
02-19-2016 07:46 AM
@tatyana-sumakov wrote:
Thank you ScottyP your very helpful just wanted to make sure before I bought anything
In general, any lens that's threaded for a screw-in filter will tell you what filter size it takes. Often you can read it right on the front of the lens. I think it's always at least near the front end.
