canon eos rebel t3 no longer connects to eyefi mobi card
ahhalperin
i have done a hard reset of my camera, re-enabled the connection, but still does not connect tl the card and transmit WiFi signal so i can transmit images
17 REPLIES 17
both the old and new EYEFI cards continue to function satisfactory
and images are stored normally. They do not transmit wirelessly as they should. That is my problem
Have you tried resetting the camera?  Your preconceptions are prohibiting [you] from considering the problem objectively.
Last call, have you tried a regular card, yet?  If not, then when?  If you think there is something wrong with the camera, then prove it.
Are you sure you have EyeFi enabled?
All the camera does is be sure not to shut off while images are being transfered. It does not control the EyeFi card. Are you sure the card is enabled correctly in the EyeFi desktop app?
enabled
jrhoffman75
Mobi card
yes, mobi card
jrhoffman75
I'm at a loss. My Mobi Pro uploads to my iPad just fine.
I really do not think its a camera issue since all the camera setting does is keep camera from shutting off while EyeFi is sending.
I tested it with my 1D Mark IV and it works fine when I enable Power Off to never.
If you are trying to upload to PC it must be a WiFi issue or a bad card.
treied it again, and it worked.
We mjust have scared it.
Use a mac
