05-12-2017 10:45 PM - edited 05-12-2017 10:48 PM
Hi All..
Just a heads up... I'm new at this, so please bare with me. :
Ive been experimenting with and having a lot of fun with my camera. But,,, I cant seem to zoom in close to a subject that is quite a distance away from me.
I have a Rebel T6i with a 18-55 lens on it right now. (And a couple other High Definition lenses).
Do I need a certain type of lens to zoom in close to a subject that is (for instance) 30 to 40+ ft away,, like wildlife? Or, is there a way to do it with the lens that I have right now?
Thanks in advance!!
Pam
05-13-2017 09:52 AM - edited 05-13-2017 09:53 AM
@Pam7 wrote:Hi All..
Thanks in advance!!
Pam
Your 18-55mm lens has focal lengths that are generally regarded as wide angle [18mm] to standard angle [~50mm]. A 50mm lens is sometimes referred to as a standard lens, because it presents an angle of view comparable to the human on a 35mm film camera.
Focal lengths ranging from about 70mm to 135mm are considered medium telephoto. Focal lengths ranging from about 150mm to 300mm are considered to be telephoto lenses. Focal lengths of 300mm, and above are considered to be super telephoto.
Many of the closeup pictures of birds that you see are usually taken with lenses with focal lengths in one of the telephoto ranges, most likely in the super telephoto range. Many "birders" like lenses that are least 400mm, with many going for 600mm.
However, many times images are "cropped" in post processing in a computer, which means the photographer cut out a small piece from a wider angle shot, which can give the impression of a super duper telephoto lens was used. The drawback to doing so is that you don't gain anything, except perhaps making flaws in the original image more noticeable.
Because of the way your camera's image sensor [ APS-C size ] is made, you camera will "see" a 35mm equivalent focal length that is longer than the focal lengths that are specified for a given lens. Your sensor has a "crop factor" associated with it, which narrows the angle of view through a given lens.
To make a long story short, your image sensor has 1.6x crop factor compared to the standard 35mm film camera. This means that a birder using a 400mm lens on your camera, will have an apparent focal length equivalent to 640mm [400mm x 1.6].
But, using "long" super telephoto lenses isn't always easy. It is almost like looking at the world through the cardboard tube at the center of a roll of paper towels, if not even worse. The longer the focal length, the longer the cardboard tube would be. I find it much easier to use a super telephoto on a tripod, than handheld, so that I can look up once in while and not lose my aim.
If you think you want to explore the world of birding and shooting wildlife, then you would need a telephoto lens, preferably a zoom lens, so that you can unzoom the lens, get your bearings, and zoom in on your subject.
That is a good entry level zoom telephoto lens. I gained familiarity with telephoto lenses using an older version of the same lens.
https://shop.usa.canon.com/shop/en/catalog/ef-100-400mm-f45-56l-is-ii-usm-refurbished
I like to use the above lens to shoot wildlife. I like to photograp like a tourist, which means landscapes and cityscapes. Sometimes, though, as I am walking around lakes, beaches, and woods, I do see wildlife. In other words, I get lucky. I used that lens to capture this photo of a bird that landed about a car length, or so, away from me. I used the 400mm setting.
Birding can be a fun activity. I have captured my best shots after being one spot for a while, and the wildlife begins to creep out of hiding. It reminds me a whole lot of fishing.
05-14-2017 02:48 PM - edited 05-14-2017 04:21 PM
"XIT Pro Series 0.43x High Definition AF Wide Angle Lens 58mm"
Pam,
I am sorry to tell you but those are not actual camera lenses. They are more like add on filters. They are really not very useful in real photographic work. You probably bought one of the "kit" packages from places like Amazon. It is a shame that so many people get caught in that scam.
What you need to do is get true camera lenses designed for your camera. What you need to look for is the millimeter focal length of the lens. For instance to shoot birds, which are very small, you need a lens with a very high number focal length. I prefer 300mm up to 600mm. Of course you can always try to get closer which serves the same purpose. However, some if not most of the time you can't or it is impossible.
A good choise would be the Sigma 150-600mm f/5-6.3 DG OS HSM Contemporary Lens for Canon or the Tamron SP 150-600mm f/5-6.3 Di VC USD G2 for Canon. An outstanding choice in the Canon line would be EF 100-400mm f/4.5-5.6L IS II USM Lens. The big problem with the mentioned EF-S 55-250mm f/4-5.6 IS STM Lens is, it too is still pretty short for serious, real bird photography unless you can get pretty close.
This is a friend of mine shooting a Mallard duck at a locl wildlife park. He is using a 300mm f4 lens.
I shot him with a 120mm f2.8 lens and this is the shot he got of the duck. He is a student of mine and is learning just like you are.
I hope this explains a little more on what you actually need. Don't buy any more of those packages and tell all your friends not to either.
05-14-2017 02:50 PM
Pam, BTW what I wanted you to notice was the distance vs the 300mm focal length being used. A smaller bird is going to be, "smaller" in the frame.
05-13-2017 11:10 AM - edited 05-13-2017 11:53 AM
I have a T6 and the 18-55mm is one of the kit lenses it came with. That lens isn't meant to zoom in on a subject "at a far distance." Unless you are shooting wildlife, you could try zooming in with your feet until you get a proper telephoto lens.
What are you trying to shoot and how far away is the subject?
EDIT: I overlooked your statement that you are 30 to 40 feet away from your subject. I don't usually think of that distance as being far away. What kind of wildlife are you trying to shoot? A bird?
05-13-2017 08:25 PM
Hi John.
At this point, I like taking pics of wild life (Moose, Caribou, Minx, bird), and flowers, I guess anything that catches my eye! 😊
05-14-2017 10:49 AM
@Pam7 wrote:Hi John.
The next lens you should get to pair with the 18-55mm lens that came with your camera, is the EF-S 55-250 IS STM lens. At under $250 direct from Canon with a 1 year warranty this lens has fantastic image quality (be sure to get the STM version). It will allow you to zoom in almost 5X as much as your current lens.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
