Reply
New Contributor
Re: Why would my canon t3i Eos say there is not a card in it, when there is?
My daughter just came up with a solution. She took out the card and breathed into the slot (like you would an old nintendo game.) It worked!!!
Very cool
Thanks!
Tim
Respected Contributor
Deoxit 5 electrical contact cleaner will take care of it if it is dirty contacts and it will not harm any plastics or rubber components either.
The moisture in a breath can cure it temporarily but I suggest using a good contact cleaner like Deoxit 5 to take care of it long term.
Highlighted
Frequent Contributor
Rubbing alcohol and a good QTip will also work (I recommend the QTip because you do want to limit the amount of rubbing alcohol that comes into contact with the plastic/paint on metal of the camera case, small amounts will not hurt but too much can damage.)
powered by Lithium
