01-23-2016 02:32 PM - edited 01-23-2016 02:37 PM
Is this because of the filters being in place? Input please. Canon T5i with EF5 zoom 18-135mm. I was using auto function without flash.
01-24-2016 11:05 AM
Bright objects, and especially bright objects on mostly dark backgronds, can create "ghosting" when you have flat filters attached to the lens. The flat surface makes a perfect "mirror" and some light reflects off the front of the lens, hits the filter, and reflects back into the lens creating the "ghosted" copy.
Higher quality filters usually have a good anti-reflective coating to reduce the effect, but I find it's better to just remove the filter completely and only use them when they are needed or helpful.
01-23-2016 03:06 PM
If by "ghost image" you mean that you see a faint second moon then maybe it is reflection from filters. You can easily and quickly test that by removing filter and repeating the shoot.
01-23-2016 03:35 PM
Thanks, John. I should have tried that instead of posting the question but it doesn't hurt to ask, right?
01-23-2016 03:43 PM
01-23-2016 03:49 PM
Deleted bad images. Should have a good moon tonight and will try without filters. I'll let you know how that goes.
Henry
01-23-2016 03:55 PM
You probably know this, but the full moon is in full sunlight, so you want to spot meter on the moon or try a "Sunny 11" exposure for a start. f/11 to a shutter speed close to 1/ISO.
01-24-2016 10:55 AM - edited 01-24-2016 10:57 AM
The Looney 11 rule is a method of estimating correct exposures without a light meter. For daylight photography, there is a similar rule called the Sunny16 rule.
Using a ISO 100 setting,you will set the aperture to f/11 and the shutter speed to 1/125 second. Or, you can use any combination of these exposure but must maintain the same EV. I.E., ISO 200, 1/200, f11 --- ISO 400, 1/500, f11, etc.
Noted, a135mm lens may not be a long enough focal length. Depending on your desired out come. Use manual mode for the settings. Shoot RAW, otherwise set the jpg to daylight. Use a tripod. And lastly bracket your exposure, a stop more and a stop less.
01-24-2016 11:05 AM
01-25-2016 08:50 AM
I appreciate all the input on this subject. Simple fix was just removing the filters. Thanks to all the contributors!
