05-05-2014 08:06 PM
Hi all,
I'm having some difficulty with my camera, and was very much hoping someone could steer me in the right direction of a solution. As seen in the photos, a consistent beam of light is showing up in each photo. I was photograping on the beach when it began, and the problem shows up no matter what lens I'm using. The camera was not dropped; the issue began all of a sudden and unfortunately continues. Any help or sugestions would be greatly appreciated.
Many Thanks!
Tom
05-05-2014 08:39 PM
Hi, tomz1!
So that the Community can help you better, we will need to know which camera model you are using. This ensures the appropriate information is provided for your camera.
We look forward to your response. Have a great day!
05-05-2014 08:49 PM
Thank you for the reply.
The camera is an EOS Rebel XSi.
05-05-2014 09:44 PM
Hi Tomz1,
This appears to be a shutter malfunction. Unfortunately, your camera will require repair. You may click here for service options.
05-06-2014 08:41 AM
Thank you very much for the reply. I figured as much, but I really appreciate hearing it from someone more knowledgeable than myself!
05-06-2014 10:05 AM - edited 05-06-2014 04:20 PM
It looks like one of the blades of the shutter has broke.
If your camera does need a shutter, as I suspect, you may want to consider and up-grade. I don't know the price of replacing a shutter on a XSi but it is likely in the $200 to $300 range.
Example a T3i is around $499. A refurb from Canon is even less.
05-06-2014 04:12 PM
thank you very much ebiggs1! I appreciate the advice, and I'm going to take it! time for a new camera!
05-06-2014 04:20 PM
05-08-2014 09:03 PM
If you do decide to look at upgrading... ask Canon about their loyalty program. This allows you to trade in your current camera for larger discount on a refurb than you would get it if you bought the refurb without the loyalty program.
The discounts and models in the program vary -- so you'll have to ask about it when you contact Canon for service and they can tell you what's currently in the program (it changes all the time.)
The main point is... if you decide you don't want to repair your existing camera, don't discard it because it's worth a trade-in credit.
