03-26-2019 06:06 PM - edited 03-26-2019 09:31 PM
My videos have come up so much more grainy than usual all of a sudden with this rainbow tinge and I can't figure out why :(. My camera has only recently started doing this. I've tried changing up a lot of settings to try and fix it up and nothing seems to be working. Here's a video of what it currently looks like https://vimeo.com/326236274. I would really appreciate any help!
I'm using an EOS 700D (t5i), my recording size was at 1280x720 50fps in that video but once I realised it could've been that I switched it to 1920x1080 25fps and it looked the same, my image quality was M but once I realised that I changed it to raw and it still seemed to look the same then as well. Please let me know if you need anymore information to help! Thank you!
03-27-2019 09:04 AM
Raw doesn't matter for video recording. Are you recording with less light than previously?
03-30-2019 10:54 PM
03-31-2019 01:18 AM
@ritz_ wrote:My videos have come up so much more grainy than usual all of a sudden with this rainbow tinge and I can't figure out why :(. My camera has only recently started doing this. I've tried changing up a lot of settings to try and fix it up and nothing seems to be working. Here's a video of what it currently looks like https://vimeo.com/326236274. I would really appreciate any help!
I suggest that you go take a step back. Capturing video at lower frame rates can be a good thing on multiple levels. First and foremost, it means your camera will have far less work to do. So, it can spend more CPU time on mundane tasks like Noise Reduction.
Another contributing factor to more grain can be your actual exposure settings. While frame rate is relevant, without knowing the exposure settings of the frames in your videos there is no good way to determine what could be the cause of the issues that you see.
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
08/18/2023: Canon EOS R5 C training series is released.
