08-25-2018 11:57 AM
Can any one tell me which models have manually variable on board pop up flash? Shooting products and need a kiss of light up front and trigger the monoblocks.
Thanks
Blake
08-26-2018 11:01 PM - edited 08-26-2018 11:04 PM
My apologies, the T2i and T3i don’t have manual flash, but the T4i and newer do have manual control available for the built-in flash.
08-25-2018 01:27 PM
Monoblocks?
No. The internal built-in flashes are not very powerful, and thus not very sophisticated. Use external flashes.
Some macro lenses have built-in LEDs.
08-25-2018 06:16 PM
All Canon DSLR cameras have manual flash capability. They all have about the same power, and if you’ve used one before for that purpose, you should have no trouble with any of the Canon DSLRs.
08-26-2018 08:46 PM
My t2i doesn't not there is no way to adjust the power of the popup flash.
Is it possible on some of the other models?
08-26-2018 09:30 AM
Remember to use manual mode, then. In ETTL you will get multiple flashes which can fool the monoblocks.
08-26-2018 08:48 PM
Yes exactly my problem with the t2i. It is impossible to control the flash ratio manually. So using the pop up for fill and to trip the monoblocks is impossble. I wonder which model can do that.?
08-27-2018 09:01 AM
Get some ND gels and put it in front of the flash.
