11-18-2020 09:08 AM - last edited on 11-18-2020 09:17 AM by Porcha
Hello, i am new to photography/videography. I just purchased a used Rebel T6i 750d camera and has the 18mm-55mm lens. I am going to start recording/ documenting my outdoor adventures. (mainly hunting and fishing.) Can i add a VariZoom LANC Zoom Control Switch to this camera to use while recording? The info i am finding keeps refering to LANC cameras. I am not sure if mine is LANC. The link to the switch is bleow. Thanks for the help.
(link removed as per forum guidelines)
11-18-2020 09:26 AM
I don't think so. I think it only worked with the 18-135mm lens of more recent vintage. I also think it was a marketing failure and has disappeared down the memory hole.
11-18-2020 12:43 PM
LANC stands for Local Application Control Bus System. LANC control is used for video equipment and connected peripherals.
Your T6i is not a dedicated video camera so the LANC controller will not work.
11-18-2020 01:01 PM
Thank you for your help!
