08-16-2017 11:01 PM
Hey All,
I am completely new at this and shot about 400 photos in RAW for my nieces birthday party and I just found out RAW images wont upload?
Any way I can go around this? If I take it to a photo place with my SD or cable will they be able to print?
Any help is greatly appreciated!
Thanks,
Melanie
08-17-2017 03:28 AM
Raw is just a file format. If any file can be put on your computer so can the raw files. You do need a raw converter to see them. to view them, but not to upload to the computer. You should have got DPP 4 with your camera. At any rate if you didn't it is free form Canon. You will need it or some other like software for the conversion.
Almost all current computers have SD slots in them from the factory. Put the SD card in it and use your computers file management system. I.E., File Explorer in Windoze. Whatever Mac has.
08-17-2017 10:36 AM
What computer do you use? What camera do you have?
08-18-2017 12:56 AM
I have an acer tablet and no slot for SD card and I have a rebel t6.
08-18-2017 05:35 PM
@segoviarivias wrote:I have an acer tablet and no slot for SD card and I have a rebel t6.
Acre tablets run Android, not Windows. As previously noted, you need a system that is capable of running Windows 10. Beware of buying the least expensive thing you can find.
The Canon DPP software has a minimum set of system requirements for the software to run. Perhaps the most important specification is the type of CPU, as well as the minimum amount of System RAM, which I am told means at least 4 GB.
08-17-2017 07:26 PM
@segoviarivias wrote:Hey All,
Thanks,
Melanie
A RAW file is a digital negative. You cannot upload that file type to social media, nor can you print directly from it. Just like in film, the negative must be first converted into a form viewable to humans, which can mean a JPEG file type.
There are advantages and disadvantages to using either file type. It sounds like you have discovered one of the few disadvantages to using the RAW file type: you cannot share the files until you convert them.
08-18-2017 12:57 AM
how would i convert them? They do not transfer onto my laptop when I attach the usb cord.
08-18-2017 06:31 AM
@segoviarivias wrote:how would i convert them? They do not transfer onto my laptop when I attach the usb cord.
I suspect your tablet may fall short of the mark.
What Operating System is it running? If it is running MS Windows, then you might be able to run the free Digital Photo Professinal software from Canon.
08-18-2017 10:37 AM
Laptop or tablet?
A laptop can handle it, a tablet probably can't. IOS can load RAWS. but they just display the JPEG preview.
08-18-2017 04:49 PM
"They do not transfer onto my laptop when I attach the usb cord."
In reverse order. Do you have a laptop or a tablet? Or, both? I doubt the tablet will work at all so forget it.
"how would i convert them?"
If you have a real laptop you need to d/l the free DPP4 from Canon. It is virtually seamless to u/l to a computer or laptop with it. With DPP4 you will be able to do whatever you want with the raw files.
So, once again so you truly understand, you need a real deal laptop or computer and DPP4. This is not splitting atoms here it is really that simple. You may find someone that knows more about Acer tablets than I but I don't think its use is possible for raw files.
