05-29-2021 04:43 PM - last edited on 06-05-2021 12:44 PM by Danny
I am unable to connect my newly bought Cannon EOS 4000D to my laptop even after I tried with wifi disabled Can any body tell me what is the problem or if it's not compatible with laptop
06-05-2021 05:18 PM
Welcome to the forum. Mac or Windows laptop?
07-16-2021 07:50 AM
@jrhoffman75 wrote:Welcome to the forum. advancedmd Mac or Windows laptop?
It is often reported that Windows 10 computers do not recognize Canon DSLRs. This post shares 9 methods to solve the ‘Windows 10 won't recognize Canon camera’ error. Also, learn the right way to access Canon camera photos and videos on Windows PC.
06-21-2021 05:46 AM
The common reasons for Windows not detecting Canon camera are: USB driver is corrupt or not updated. Install the wrong version of Canon EOS Utility software. Windows 10 not updated.
07-06-2021 05:50 PM - last edited on 07-07-2021 09:42 AM by Danny
@Kidd259 wrote:
@usama265 wrote:I am unable to connect my newly bought Cannon EOS 4000D to my laptop even after I tried with wifi disabled Can any body tell me what is the problem or if it's not compatible with laptop
I couldn't get my canon to sync usb until I disabled the wifi and NFC on the camera. It was as interfering with the camera connect somehow
I think this post is spot on the money. I don't think you can connect to a computer via Wi-Fi, just smart devices like phones and tablets. You will have to disable all of the wireless connectivity, enable the USB connectivity, and use a USB cable.
07-06-2021 05:15 PM - edited 07-06-2021 05:53 PM
Does your laptop have an SD card slot or USB port? If it has an SD card port I recommend simply removing the SD card from you camera and inserting it into the computer, if you have a USB port, simply get a card reader and that will work fine. It should be just as fast to do, will download faster and will not drain your camera battery in the process.
08-30-2021 11:51 PM - edited 08-31-2021 11:35 PM
I got myself a Canon EOS 4000D last week, and when I connect it to my PC, my PC won't even acknowledge that the camera is connected. The camera has a USB mini connector which I found odd since to me this seems a bit outdated. Is there a new type of USB mini, or is it something else?
08-31-2021 07:28 PM
Nope a regular old USB-Mini. Newer cameras have USB-C
08-31-2021 07:52 PM
Are you using the cable that came with the camera? Some cables are only charging cables; the one Canon supplies is a data cable.
Is WiFi turned off?
