01-16-2021 04:25 PM
01-16-2021 04:34 PM
01-16-2021 04:37 PM
01-16-2021 04:47 PM - edited 01-16-2021 04:48 PM
With the 10-18 lens, the widest possible aperture is f/4.5. But if at the 18 end, it's f/5.6.
Do you have a tripod? If so, do some longer exposures. e.g. if you shot say at 1/60s at ISO 3200, you could drop that to ISO 100 and use 1/2 second.
01-16-2021 05:57 PM
01-17-2021 12:37 PM - edited 01-17-2021 12:37 PM
Here are the results. The last photp i was messing around with the exposure trying to fix the overblown window situation. Any tips on dealing with that? Thanks
01-17-2021 12:47 PM - edited 01-17-2021 12:49 PM
Two things strike me right away. Make your verticals VERTICAL and if you want advice on lighting for real estate get the reference I suggested. It is cheap as a downloadable PDF and has masses of information on this subject from a recognized expert. If you don't like reading he has a video series out now:
01-18-2021 09:17 AM
The only way to avoid blown out windows are to greatly increase the lighting in the room or use HDR.
01-18-2021 11:04 AM
"The only way to avoid blown out windows are to greatly increase the lighting in the room or use HDR."
The only real way to avoid blown out windows is to use a good post editor. HDR can be helpful, too but Lightroom and/or Photoshop is the answer. It will allow you to adjust the verticals too. Use Raw format to increase the ability to edit.
01-18-2021 11:35 AM
Or, use ND gel sheets or one to two stop meshes on the outside of the windows.
