09-30-2019 09:53 PM
09-30-2019 10:57 PM
Check to see if your editing software can fix vignetting. That is what you need.
Of course, this is what you get if - to try to be charitable - use less than optimal non-canon lenses.
I strongly suggest you look at the EF-S 55-250 mm lens. It will get you even more reach at much better quality.
09-30-2019 11:07 PM
10-01-2019 10:07 AM
Unfortunately the bundled kits sold on sources like Amazon and eBay are either junk or useless. There really is no other way to describe them.
Editing software is not likely to fix the black circle problem because there likely isn't any photo info in it.
10-01-2019 11:12 AM
10-01-2019 12:47 PM
"...since it is a new camera for me."
On the bright side you learned something about photography. That's always a good thing. SOmetimes it is an expensive thing! I just wish you had come here first.
