Reply
Forum Elite
Re: T7i Battery Grip.
This seems pretty clear!
"At this time Canon does not have a dedicated battery grip for the EOS Rebel T7i.  We apologize for any inconvenience that this may cause you at this time.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well."
Doesn't it?
Respected Contributor
Yes until Canon's UK site has this battery grip for the T7i, that's what muddied the waters...they still have not taken it off after admitting it was a mistake https://store.canon.co.uk/canon-bg-e8-battery-grip/4516B001/?nav=accessories%2Ccameraaccessories%2Cb...
Honored Contributor
@Waddizzle wrote:
@John_ wrote:
Yeah, go figure that one out! I guess it is a wait and see deal. Will be interesting to see if that UK site removes it from the list of battery grips.
In addition to the lack of control contacts, I would also be worried about the actual operation of a third party grip.
Consider how a grip works.  First and foremost, some cameras are not designed for use with a battery grip.  A battery grip does not connect two batteries in parallel, which could cause the batteries to short out one another.
Cameras that use battery grips seem to only use one battery at a time, and alternate between the two batteries as their charge gets used up.  I am not so sure that a camera not designed for a battery grip has the smarts to do that.
Maybe I am wrong about how a grip works, or how a camera interacts with the batteries.  One thing is certain, though.  The batteries are not connected in parallel, as that would smoke the batteries.
I can look in my menu at the battery status, and I can see the percentage charge remaining on each battery.  Immediately after a recharge, the will both read 100%.  After a little bit of use, one may read 98%, while the other may still read 100%.
If I take some more shots, then the second battery will start showing signs of discharge.  It might drop to 96%, while the first will stay at 98%.  At this point it might switch back to the first battery discharging.
To me, it strongly suggests that the camera body can read the remaining charge on the batteries, and switches between using one or the other.  What does that tell you about how a battery grip might work?
Isn't it far more likely that the battery switching is done within the circuitry of the grip itself?
Does the camera actually differentiate between the two batteries, as you seem to imply? If so, even that surprises me. I wouldn't have expected the camera to know that a second battery is present.
Full disclosure: My first-hand knowledge of grips is zero. They gave me one free when I bought my 5D4 last spring, but I've never used it. I guess I could live with the additional weight, but the extra size is a show stopper.
Bob
VIP
I am almost certain that the batteries take turns being the lead or lag battery.  Ohm’s law says that you cannot connect the batteries in parallel.  You could if you connect them with additional diodes and load resistors, but doing so would only detract from battery life.
When you use a battery grip, the camera can see both batteries separately.  It can display the serial number and remaining charge of each battery.  I wish I knew how to take a screen shot of the rear display, short of taking an actual photo.  It can even display which battery is in which position inside of the grip.
I do not see evidence of any electronics in a the battery tray or the grip.  There might be something inside of the vertical piece that sticks up into the camera body.  The camera can read the real time status of both batteries at the same time, which strongly suggests that both batteries are connected to the camera.
With all of the extra contacts in the battery compartment, it makes more sense to put any smarts in the camera.  You can implement any battery switching in the firmware.  This is a much better arrangement, and a far less costly arrangement, than putting any electronic components in the grip.
Batteries can and are often connected in parallel to increase the MAH while the total voltage remains the same. In series the voltage of the batteries adds together while the MAH remains the same., of this I am sure. One basic example is jump-starting a car, the batteries are connected in parallel. The only damage you can cause leaving 2 car batteries connected in parallel together is if the alternator tries to charge them both it could be damaged but not the batteries. In my Logitech mouse, the 2 AA batteries are connected in parallel which makes it last longer, more MAH and I can remove one battery and the mouse still works.
As far as the internal circuitry, anything is possible.
Forum Elite
"The batteries are not connected in parallel, as that would smoke the batteries."
If you don't know, make it up? Smiley Frustrated
"As far as the internal circuitry, anything is possible."
Absolutely.
VIP
Sorry, you cannot connect any type of battery in parallel, as they would short together.  True, they can reach a equilibrium point, but the batteries need to be closely matched electrically.  I would not mix batteries from different manufacturers.
When it comes to cars, you are talking about a lead-acid batteries, and you are talking about a brief connection.  I have also seen a dead battery in one car, kill the batttery in a ssecond car used to jump start it.
As far as the circuitry goes, anything is possible, but some things are improbable, while other things make no sense.  You have your opinions, while I have my facts.  The batteries in a grip discharge separately, and alternate as they do.  To me, tha tis proof positive that they are not connected in parallel.
VIP
Absolutely.
 Warning,  You are crossing the line, once again.
Honored Contributor
There are references, in this thread and elsewhere, to the use of 3rd-party grips in Canon Cameras that weren't designed to accept a grip. How could such a grip ever work unless it had the necessary circuitry built in?
Bob
VIP
[ Edited ]
You are comparing apples to oranges.
You are comparing a third party grip for a camera not designed to use one, to the manufacturer’s grip for a camera that is designed to use one.  If you are not, then we are talking about two entirely different things.
You can safely connect barteries in parallel with a simple resistor, and a diode to prevent reverse current flows.
[EDIT]. Remember, the question is not can you connect them in parallel.  The question is why do the batteries seem to alternate discharging if they were connected in parallel.  In fact, how can the camera read and identify them separately if they batteries were connected in parallel?
I conclude that there is zero probability of the batteries being connected in parallel.  It is not a question of can it be done.  It is question of how it is being done inside of the grip.  And, being connected in parallel ain’t it.
powered by Lithium
