09-14-2020 07:51 PM
Is there a wireless flash trigger that works with the T7, which doesn't have the center contact on the hot shoe. Any trigger I can find that specifies what cameras it works with note that it doesn't work with the T7 or SL3 cameras.
09-15-2020 04:22 AM - edited 09-15-2020 04:22 AM
Would it not be simpler over the long run to upgrade the T7 to a camera that is compatible with a wider range of gear?
You will be fighting this same fight over and over again with the T7. It is a safe bet that well over 90% of T7 users never buy an external flash. I would not be surprised to learn if that figure was over 99%, which could begin to explain why Canon removed the circuitry from their most basic, entry level cameras.
If you wish to get the most performance from flash gear, I suggest that you upgrade the T7, and the leave Rebels behind.
09-15-2020 11:49 AM
3rd party ETTL remote transmitter/receivers like the Godox X1T-C and Yongnuo YN-622C-TX will work, but you may need to update their firmware to be compatible.
