12-29-2020 08:07 AM
Coming from a T5i, my T6s focusing is different. I'm not able to get 1 dot focusing point even though following directions on videos I've seen.
I select 1 pt AF but when trying to take a picture, I still get several
Any help is appreciated
12-29-2020 08:21 AM
Welcome to the forum. The T6s is more complicated than the T5i when it comes to settings.
eos-rebelt6s-760d-bim2-en.pdf (c-wss.com)
12-29-2020 08:25 AM
Yes, have done this.
If I focus on a subject, I don't get 1 square, Let along a red one
What dial setting should I be using?
12-29-2020 08:33 AM
Not sure I understand. Do you mean the camera isn't focusing?
If you set the dial to Green Square do you get multiple focus points showing?
Try setting camera to the P mode setting and see what happens.
12-29-2020 10:05 AM
Even though it is only focusing at one point, it will show all points in focus. As long as your single point lights up, you are good.
12-29-2020 11:47 AM - edited 12-29-2020 12:01 PM
I can't figure out how to get to manual. Choices are man selection 1 pt, manual selection zone, and auto selection zone,
All points light up red and when trying to take picture there are some squares, but none light up
12-29-2020 12:01 PM
@cruisinfanatic wrote:I can't figure out how to get to manual. All points light up red and when trying to take picture there are some squares, but none light up
What setting is your mode dial at?
Is the lens switch set to AF?
What are you trying to photograph?
12-29-2020 12:18 PM - edited 12-29-2020 12:18 PM
lense is af.
could problem be because using
Tamron 16-300mm?
used for birding
Even on auto, all squares there are black. None ever are red
12-29-2020 12:23 PM - edited 12-29-2020 12:30 PM
@cruisinfanatic wrote:lense is af.
Tamron 16-300mm?
used for birding
Could be. Looks like this lens is f/6.3 at 300mm. T6s will only AF up to a lens aperture of f/5.6.
Try setting zoom at the 16mm setting and see if anything changes.
Also, do you have a Canon lens to try?
12-29-2020 12:38 PM
changing lense made no difference. Still unable to get a single focal point even though it's set that way
