T6 - Shifting and Discolourization in Image Files
canphoto
Hello.
I use a T6 to capture images for work. When using the camera this week we encountered significant image problems in at least 50% of our images. The images shift horizontally or vertically and have discoloration bars.  It seems the saving of the image file is incomplete.  We've never had this problem before on this or on a T4 Canon, nor any other DSLRs I've used.  We are using a Sandisk Extreme 90 MB/s 32GB SD Card. After every use and file transfer, we perform a Low level format of the card.
Sample images are included below.
If you have any knowledge of what might be happening and how to avoid it in the future, please let me know.
Thank-you!
6 REPLIES 6
kvbarkley
VIP
VIP
Does it happen with multiple cards?
Is this a micro card with adapter?
My advice: throw away that card and make sure you use a Full size SD card as specified by Canon, and format it in camera - most of which you already do.
Thank-you. We use a full size SD card purchased in May. It has not happened on other cards.
Your sage advice aligns with our thoughts. A new card may be the best way to go. Thanks again.
Also, is this RAW, JPEG or RAW+JPEG?
JPG alone at this point.  Thanks.
Ok, try a new card, then.
ebiggs1
New SD card. Get the exact SD card outlined in your manual.
Enter for a chance to win!
April 20th-28th
