Reply
New Contributor
T5i - remote control, adjust timer?
Have a new remote for my T5i, got it working OK but I have a question.  The default setting for using the remote is to have a 10 second delay, questions:
can you change the 10 second delay for the remote?
can you use remote and have multiple shots at once, say 5 shots burst?
thanks
VIP
Re: T5i - remote control, adjust timer?
I'm pretty sure that the remote control would work with the camera set for 2 second delay mode, too.  The camera itself generates repetitive triggers of the shutter for continuous shooting.
Continuous shooting using a remote would be up to your remote control.  Your camera will not take pictures with the remote as fast as it can when it is set for continuous shooting mode.  A remote shutter control will not boost the frame rate.  It is likely that the camera could be damaged if you tried to do so.
New Contributor
Thanks for the reply..
I double checked and tested, it works only on the 10 second mode
So the reason I bought this was to help photograph some wildlife in our yard that I cant get near, I am guessing this is not the answer
Respected Contributor
There should be a switch on the back of the remote that changes that.
New Contributor
Ahh, had assumed it had two channels on it, but that works great !
powered by Lithium
