Reply
Highlighted
New Contributor
Accepted Solution
T4i battery drainage.
The battery in my T4i seems to be draining quicker than it should, even when turned off.  Anyone else having this problem?
Highlighted
Respected Contributor
Re: T4i battery drainage.
How quick is quicker than it should?  How are you using it, things like Live View and very long shutter speeds will eat up the battery much quicker than "normal" use.
Highlighted
New Contributor
I rarely use live view and the battery seems to run out of juice after taking about 40 - 50 shots.  After being turned off, it stills drains the battery.
Highlighted
Yeah, that's not normal.  Do you have more than 1 battery?  I'd check with another and see if you get the same response.  If not I'd suggest buying a new battery.  I fully support use of 3rd party batteries, but if I was having battery trouble then I'd spend the extra coin and buy a Canon battery to make sure it's not the camera.
Highlighted
New Contributor
Unfortunately, the Canon battery is the worst of all.  Luckly I have 4 others.  Thanks for the info.
VJ
powered by Lithium
