06-11-2013 08:22 PM
When I conect the camera to the monitar with the HDMI cable & try to play the video I have on the cam all I get is the first frame of the video but I cannot get the video to play with nothing I try !!
If I turn the cam to movie & start recording while conected to the monitar it will show a live picture ! But I cannot replay the clip after I record it ???
06-18-2013 09:39 PM
Hi Bkieffer,
So we may better assist you, with your camera connected via the HDMI cable and the camera on and in the playback mode, what do you see on your camera's display?
06-18-2013 10:19 PM
With the camera on when I push the play back button while connected to the monitor the camera screen is black !!
06-24-2013 05:49 PM
Hi Bkieffer,
Since the display is going dark, the camera correctly detects the display.
I recommend checking the monitor to ensure that the correct HDMI terminal is selected. If you've been using an automatic selection mode, I recommend manually selecting the correct HDMI terminal, if you have that option.
