Reply
Highlighted
New Contributor
T3i stuck on "sensor cleaning" screen!
I haven't used my camera in about a month and today I turned it on and none of the buttons would work. The screen was just frozen but the "sensor cleaning" icon was flashing. It didn't even turn off. I had to remove the battery. Now, it's stuck on the "off" screen where is says "sensor cleaning". To turn it off, I still have to remove the battery (I have an external battery on it). Help?!
Highlighted
VIP
Re: T3i stuck on "sensor cleaning" screen!
"(I have an external battery on it)."   Smiley Frustrated
As in a battery grip or a AC adapter?  If a battery grip and it is an off-brand get rid of it.  Remove it and install a new Canon brand battery.  If it is the AC adapter do the same.
Highlighted
New Contributor
HAve you figured anything else out with this issue? I have been having the same trouble and can't find anything anywhere.
Highlighted
VIP
In his case it may be the grip.  Third party grips are notoriously bad.  Do you have one as well?
Highlighted
New Contributor
[ Edited ]
No. It is a factory new camera. No additions except a uv filter.
Highlighted
VIP
Did you do a "Clear all settings"?  Do so.
Highlighted
New Contributor
I did. No change. I have to remove the battery to turn it off and when I turn it back on it indicates sensor cleaning again. Unless I have the memory card compartment open when I turn it on. Then it starts up fine.
Highlighted
VIP
I am no fortune teller but, I believe Canon service is in your future.
powered by Lithium
