04-28-2015 09:12 PM
Hello,
A few months back, I went to use my Canon T2i for the first time in a long time. The sensor cleaning icon appeared and the camera was unresponsive. After a considerable amount of time (10-15 minutes), the cleaning stopped, and I was able to take a photograph. Mistakenly thinking the issue had resolved itself, I turned the camera off.
I haven't been able to use it since.
When I turn the camera on, the sensor cleaning icon appears, and the camera becomes unresponsive to absolutely everything: pressing menu, making another selection (say from Av to P), or anything else. It doesn't even turn off when I flip the switch; I have to remove the battery. I left it to see how long it would take to turn off after flipping the switch and 20 minutes later, it was still cleaning. I finally broke down and removed the battery.
I couldn't find anything online about this. The best I could find was taking the battery and SD card out for awhile, which I did. I took them out for weeks. No dice; the sensor cleaning issue still exists.
Not knowing what to do or if I should pay to have this fixed, I left the camera fallow. Then my uncle, who has higher end Canon cameras than I do, told me to look for a CMOS battery, remove it and the regular battery, and try again. To the best of my searching, This camera doesn't have a CMOS battery ... so that won't work.
Any ideas on what's wrong, what I should do, or if this is worth paying to have fixed?
Thank you in advance for your feedback!!
04-29-2015 11:13 AM
