07-23-2016 11:12 PM
Folks,
I need some help. I just got a T6S and my Sigma 17-70 2.4 works fine except when I want liveview of try to use video mode. Neither will display anything on the LCD. The lens works fine on my T5i body, including liveview and video. My other lenses seems to work fine on both my T6s and T5i for Liveview...
Any ideas or help?
Stilgar99
07-25-2016 09:56 AM
Google is your friend.
http://www.sigma-photo.co.jp/english/new/new_topic.php?id=514
09-27-2016 02:48 PM
09-27-2016 04:03 PM
It sounds like, at least from your experience, that Sigma is getting better CS. Of course it wasn't very good at all a while back so the only thing they could do was make it better.
06-10-2017 09:19 AM
I realize I'm replying to an old thread, but Sigma released a new firmware update recently for this lens, which I just updated using the USB dock.
As an FYI --- I have a T6s and this lens works well with it, with the exception of not making the lens serial number available to the camera. Both the camera lens menu, and the EXIF data show the serial number as "0000000000". This becomes a small issue when using Adobe Lighroom, in that you need to manually select the lens model in LR before it will apply lens corrections. 😕
Albert
06-10-2017 10:16 AM
@albertj358 wrote:I realize I'm replying to an old thread, but Sigma released a new firmware update recently for this lens, which I just updated using the USB dock.
Albert
Create and use a Lightroom Preset during Imports.
I have a couple of fully manual lenses, which do not write any EXIF lens data. I use a Lightroom preset during Import to apply lens correction. I have separate presets for each manual lens. Even without a preset, it is easy to correct one photo, and then apply the correction to the rest of your imported photos.
It is such a small issue that it is almost not worth complaining about.
06-10-2017 10:29 AM
> "It is such a small issue that it is almost not worth complaining about."
Yup, which is why I haven't bothered doing anything about it.
> "Create and use a Lightroom Preset during Imports."
I'll have to experiment with this. Along with the Canon T6s / Sigma 17-70 images, I also import a large number of scans from a Canon 9000F MkII scanner, where I can't even identify a camera, let alone a lens. 🙂
06-10-2017 10:43 AM
@albertj358 wrote:> "It is such a small issue that it is almost not worth complaining about."
I have created different presets for each of my fully manual lenses. In fact, I use a preset for all of my Imports just to apply a lens correction to all of the imported images. Lightroom does not apply any lens correction, not by default AFAIK.
You have to pick a preset on the right side of the window, above the CANCEL button..
