03-07-2021 08:06 PM - last edited on 12-02-2022 11:46 AM by Danny
I have a Canon EOS Rebel T100
I’m trying to find if there’s a way to save in a zoomed in photo on the canon.
For example, when I open the camera roll and use the zoom feature it displays a high quality zoomed in photo, on my computer when I zoom in it has bad quality. So is there a way to zoom in using the + on the camera then saving it and exporting it onto a computer?
03-07-2021 09:56 PM
No, you have to use the cropping feature of your image processing software.
03-08-2021 01:37 PM - edited 03-08-2021 01:40 PM
The screen on your camera is very small and with relatively low resolution. Consequently, images magnified in the camera's LCD may appear better than they will on a higher resolution and much larger device like a computer screen or even a decent TV. When you zoom in using the method you describe, you are magnifying the pixels that make up the image, so the more you magnify, the more pixelated: or if you will, poor quality, the image will appear. This is called digital magnification.
If you want to get your images larger, then basically you need to get a lot closer to your subject, or you need to use a camera lens that will make the image larger within the sensor to begin with - get a lens with a longer focal length.
