06-15-2014 10:34 PM
06-16-2014 09:28 AM
It is probably time to buy a new camera battery. Or it could be your charger. Can you try a known good battery?
I don't think the "keep alive" battery is replacable on this model. Maybe it is but I don't think so. At any rate if it were dead it would not prevent the camera from turning on.
06-18-2014 11:38 AM
Thanks so much. I had a feeling that I would be stuck. It might be better to purchase a new body. Alan who also responded gave me some ideas to triy too. Thanks everyone!!
06-16-2014 02:31 PM - edited 06-16-2014 02:36 PM
Even a bad internal "time/date" battery should not prevent the camera from working off the main/removable/rechargeable battery. (Date and time just need to be reset each and every time the camera is turned on... Tho it probably can be used without setting them, in which case the info in images would be wrong.)
The cameras that have a non-replaceable "date/time" battery seem to use one that gets recharged by the main battery each time it's used.
As you have already been advised, most likely you just need a new main battery, though a failing charger is another possibility.
However, has the camera been sitting a long time unused? I have seen batteries go so dead, that you need to run them through a half dozen or more charge/discharge cycles before they come back up to full power. First time charged, the camera might not come on at all or might turn off in seconds. 2nd or later charges each power up the camera a little longer, until finally it works more normally. I don't use the LP-E5 batteries, so am not sure if they do this the way some other batteries do.
Camera's die for other reasons, too. It would be great if you could borrow a known-good LP-E5 battery from a friend to try, before going out and buying new.
Alan Myers
San Jose, Calif., USA
FLICKR & PRINTROOM
06-18-2014 11:40 AM
Thanks Alan, I'll try the re-charge battery trick, and using someone else's battery to make sure that "charging" isn't the problem
06-26-2014 11:01 AM
Hi all you helper!!!! I'm thrilled. finally got the new battery charger from Amazon AND it worked. Wow.
Thanks so much.
