09-12-2020 06:24 PM
Hello there, I am in need of help. I am having a problem removing all the overlays for live streaming. The overlay I cannot seem to remove is the Frames per second information as well as a timer. The program I am using for live streaming is VMIX and I can zoom in to remove the resolution frame but I just cannot seem to figure out how to remove the FPS information. Anyone have any tips or is this camera not able to have a clean output? Thank you for your time.
09-13-2020 01:21 AM
09-13-2020 01:55 AM
Hi Sir, Thank you for your quick reply. The overlays I am talking about are in the camera features themselves. For instance like the red dot and the word record flashing on the camera screen. I have everything removed except what is displayed in the photo attached. (picture zoomed out and blurry on purpose) This is what the stream would have on it if it were live.
09-13-2020 07:58 AM
There probably isn't a way to clear it out. The T5 was the bottom of the entry level camera when it was released.
09-13-2020 11:49 AM
09-13-2020 03:05 PM - edited 09-13-2020 03:05 PM
@hshuler86 wrote:
Thank you so much. I was honestly thinking you would say that. Too bad. I am still hopeful and maybe canon will make it stream capable soon...or something
Don't hold your breathe. The T5 has been superseded with newer cameras at least twice.
09-20-2020 11:49 AM
01-03-2021 06:31 PM - last edited on 01-15-2021 11:18 AM by Danny
You can remove all overlays with MagicLantern. I have my rebel t5 setup for streaming with the kit 18-55, a dummy battery, a $15 video capture stick (knockoff camlink. Works just like a webcam. I set everything to automatic for when I have different lights on/off and then just manually focused where I'll usually be sitting.
PS. I hyperlinked everything that I'm using minus the desk mount which is just a tripod upright inside of my monitor stand. They're not affiliate links so I don't actually benefit in any way from linking them!
Hope this helps,
Ryan
[Commercial links removed per forum guidelines]
06-10-2021 04:31 PM
