Reply
New Contributor
Accepted Solution
Recording issue
I have a EOS rebel T3 that pretty old but never had any problems with it until yesterday. In the middle of me filming something for my class project the screen start to glitch and the camera froze so i had to remove the battery to completely turn it off and put it back to turn it on. Now everything else works however every time i try to record anything it was glitch up and my camera will freeze. I tried making sure it was charged but idk what else to to everything works normal until i press the record button.
Esteemed Contributor
Re: Recording issue
Try a new SD card, of the correct speed value, and formatted in the camera.
Valued Contributor
Re: Recording issue
Are you using a full size SD card or a micro SD card with an adapter? Have you formatted the memory card in the camera recently? Ever?
Highlighted
New Contributor
Re: Recording issue
I’ve used both my full size and Micro sd card and formatted both. I used both lenses i have which are 75-300mm and EFS 18-55 and i still get the glitchy screen idk what else to do
New Contributor
Re: Recording issue
The issue haven’t hasn’t been solved ignore that post
Re: Recording issue
Don't use the micro SD. Other than that, you might try calling Canon and they can talk you through some things to try.
Re: Recording issue
Did you low level format?
powered by Lithium
