09-27-2021 06:29 PM
My daughter in law gave me a t3i camera that belonged to her grandpa. He only took 5 pictures total before putting it away. I have been taking pictures with it and so far seems to be working good. I put a better SD card in it and got some extra batteries for it. I also bought a Canon 50mm macro lens and rokinon 14mm wide angle lens. My main two interests are taking pictures of the homemade soap and cosmetics that we sell and shooting the stars.
Would anyone recommend that I take it to a camera shop to have someone look it over and make sure everything is correct? I also thought about cleaning the sensor lens. I would love to hear someone else's thoughts.
09-30-2021 10:42 AM
I would use RAW.
10-02-2021 02:01 PM
10-02-2021 02:08 PM
10-02-2021 04:02 PM
Here's an article.
10-02-2021 04:06 PM
10-04-2021 08:24 AM
10-04-2021 08:53 AM
Good. Looks like you have dialed in your settings.
There isn't; Sequator doesn't have a browser.
Here is a good tutorial if you haven't seen it.
10-04-2021 11:34 AM
HERE'S the link and I have put a before shot in there as well. The final processed shot is off a little because I moved the camera because I didn't have enough confidence that I had everything right. I know that I have it dialed in now and on the next good night I'm going to do a lot of different shots at many different areas of the night
sky.
https://www.dropbox.com/sh/zy1bic9n9eel2t0/AABEgKBfSGyQQvRLcm1qA0d5a?dl=0
10-04-2021 11:48 AM
Depending on the result you want, you might consider changing camera settings to 30 seconds at ISO 1600. It would darken the sky and help the stars stand out better.
If you know where north is at your location you can point the camera to the North Star and get circluar trails. Or choose other directions to alter how the trails look.
10-04-2021 10:21 AM
10-04-2021 01:03 PM
