04-09-2015 11:24 PM
02-25-2016 02:25 PM
My rebel t3i wouldnt turn on! Thougt it was the battery so I bought a new one. Didn't work. Read some post and thought maybe there was a loose connetcion where the battery goes or the memory card. If either one of those isn't secure it won't work. Not the case. It was my memory card, I has switched it from my Nikon to my Canon and it wouldn't work. I put the memory card into my Mac, deleted everything off of it, put the card back in and the camera works fine. Years of using cameras and I guess I am an idiot....but you don't switch memory cards back and forth unless you format them first. MY BAD.
Happy to have finally solved this problem and at no cost..except now I have a back up battery..which isn't a bad thing.
10-15-2018 03:42 AM - edited 10-15-2018 03:44 AM
Please see the above two posts relating to this matter.
Update: I took the camera with me to Greece during the summer. It worked fine all of the time and didn't need the terminals to be blowed on. What we have here folks is probably a temperature-related electrical fault. The heat from one's breath increases the temperature in the camera and temporarily resolves the switch-on problem. My guess is that when we go to New York in late December, we will have some major issues with the camera because of the cold weather.
11-10-2018 03:34 PM
Sounds like the moisture in your breath was just enough to allow the contacts to get cleaned when the card and or battery was inserted. If the problem comes back and blowing works again or doesn't I would buy a can of Deoxit 5 or the small bottle of it and use that to clean off the internal contacts. Spray it or brush it on the card's contacts and the battery's contacts, insert both, remove both a few times to clean them better.
12-02-2019 11:03 AM
@John_ wrote:...I would buy a can of Deoxit 5 or the small bottle of it and use that to clean off the internal contacts...
Deoxit 5 is a truly miraculous elixir, isn't it?
12-02-2019 11:12 AM
Deoxit 5 cannot be beaten!
12-02-2019 10:11 AM
evanphilipps - thanks so much for your post describing a way to solve the T3i malfunction with a fully charged battery!!!!
I formatted my SD 128GB card using my MacBook Pro, popped the SD card in my T3i, turned the switch to "On" and
cautiously openned the screen - and voila! - works fine!!!
06-12-2020 11:00 AM
06-12-2020 11:02 AM
