08-21-2016 02:13 PM
I have read other posts on this subject. They are now years old. I wondered if anything new has come up as the answer to my problem has not been found.
I have used the same card since I bought this thing in December of 2015. Never had a problem.
Now our of the blue, the card can't be read and it will not format. I have tried other cards. They too cannot be read or formatted.
I had a shoot today, at the Santa Cruz Boardwalk and wound up having to use my cell phone. Not quite the same thing, you'll agree.
So, is the bottom line that I must send this back for repair? Will it matter as others have done so and the same problem occurs again in a few months?
Does anyone here have any suggestions or should I just get it fixed, sell the sucker and go back to Minolta?
Thanks for your input.
08-21-2016 02:53 PM
Does the camera switch on?
Does it report that there is no card installed?
If you look in the card slot does it look any of the pins on the lens side of the slot are bent?
08-21-2016 03:02 PM
Yes, it turns on.
Yes, I get the message:
"Card cannot be accessed
Reinsert/change the card or
format card with camera."
So I try to format the card and it says:
"Cannot format
Change card"
There is nothing in the slots. Today is the first time I ever removed the card. There is nothing in there. I have looked, tapped and shook, everything is clean.
08-21-2016 03:23 PM - edited 08-21-2016 03:24 PM
I'll just throw thoughts out; I don't know for sure what your problem is.
1. remove battery, switch camera on, wait a few minutes, switch off, reinstall battery. Try again.
2. If no success give Canon a call at 1-800-OK-CANON.
08-29-2016 09:11 AM
Sadly, nothing has worked. Canon has infome me that it IS a problem with the camera and must be sent in for repair. So I've sent it in. I wish they would correct the problem so we don't find ourselves without a camera 6 months into the putchase!
08-29-2016 09:44 AM
@JessieLilley wrote:Sadly, nothing has worked. Canon has infome me that it IS a problem with the camera and must be sent in for repair. So I've sent it in. I wish they would correct the problem so we don't find ourselves without a camera 6 months into the putchase!
Look at the good side: If you're going to have a problem that requires repair, it's better to have it before the warranty expires.
And to your point about being without a camera: Yes, it's inconvenient. But if you've become serious enough about photography to try to debug problems yourself, or even to read and contribute to this forum, you probably have at least one previous camera at your disposal. The more you get into photography, the more cameras you'll probably have. So having to send a camera in for repair occasionally shouldn't be a show-stopper.
08-29-2016 10:00 AM
08-29-2016 01:01 PM
Just out of curiousity, what brand and capacity size is the card? Is it a micro-card that requires an adapter?
08-29-2016 01:15 PM
The card is 8 mg FujiFil. According to Canon, the card itself is fine, as is the 16 MG PNY. The PNY is a back up. The FujiFilm has worked fine since I purchased the camera.
It's not the card. It's the camera. Unless Canon is lying to me, which I doubt.
08-29-2016 01:30 PM
I have never used either brand for SD cards. However, if the thumb drive performance is any indication, PNY makes terribly unreliable thumb drives. Just make sure that your cards are Class 10, full size cards.
