06-28-2015 09:02 AM
Rebel T5 is not capturing images when taking photos in live view mode. Live view is enabled but auto focus and image capture is not working. Any suggestions?
07-01-2015 09:55 AM
troyantonik,
What lens do you have and have you tried other lenses with your camera to see if they also do not autofocus when you press the shutter button down halfway?
Just in case a setting may be causing this, I recommend that you reset the camera to the default settings. Please do the following:
06-30-2015 10:50 AM
Hi troyantonik!
Thank you for posting.
When you enable Live View and the image is shown on the LCD, then press the Shutter Button down halfway, what happens?
07-01-2015 08:46 AM
Nothing happens when shutter is pressed halfway.
I believe the camera should autofocus at that point but nothing happens and none of the viewfinders points focus or turn green.
07-01-2015 09:55 AM
troyantonik,
07-16-2015 01:35 AM
07-16-2015 08:38 AM
That is consistent with my experience.
07-17-2015 06:04 PM
Hello Troyantonik,
Since the issues with your camera seem to persist, we would recommend having the camera evaluated at the Canon Service Center. You can set up service through our web site, located here.
