03-26-2016 10:44 PM
04-08-2016 09:10 AM
There is a dark/light pattern in sky. I've seen similar when folks wet cleaned sensor and did a poor job.
04-08-2016 09:25 AM
The res is too low and pixelated for me to tell for sure. You might be right. It may be all the lens is capable of. Sending it to Canon is the sure way to tell.
04-08-2016 09:56 AM - edited 04-08-2016 10:04 AM
Take a new sample of the same sky and shoot in raw. Upload the file wherever you want. For example at filedropper.com.
I ask you for a raw file because it is hard to tell if the thingy at the sky is jpg compression or something because of sRGB.
For me it seems "normal" and has nothing to do with wet cleaning or broken things in the camera.
04-08-2016 10:29 AM
"For me it seems "normal" and has nothing to do with wet cleaning or broken things in the camera."
I tend to agree.
04-08-2016 10:41 AM - edited 04-08-2016 10:48 AM
It is called posterization.
It is caused by the 8-bit JPG not having enough data to give you a smooth gradient when large blocks of color slowly change. You’ll often see it in the blue sky in landscapes, or as in this case, with large areas of color in the background.
Shoot in raw, edit in 16 bit tiff and in Photoshop, save for web. You will still be able to see, but much less of it.
04-08-2016 11:17 AM
