01-15-2021 06:18 PM
I have a gift at lens ,is there an adapter that I could buy that will fit the gift at lens to fit my rebal txt?If so where can I buy it?and what is it called? Thanks any help would be appreciated...Newbie here...
01-15-2021 09:02 PM
What kind of lens is it? It probably not worth the trouble to adapt it.
01-16-2021 11:07 AM
I am a vote against adapting the lens, too. Usually adapters for lenses not designed to work on a specific camera are often less than ideal.
01-16-2021 01:37 PM
@Ashbro29 wrote:I have a gift at lens ,is there an adapter that I could buy that will fit the gift at lens to fit my rebal txt?If so where can I buy it?and what is it called? Thanks any help would be appreciated...Newbie here...
Ashbro,
You say you were gifted an at lens. I'm assuming that you mean you were gifted a lens that was on a Canon AT camera. If that's the case, those cameras used an FD mount.
You can buy a Fotodiox Pro adapter for about $35.00. Just be aware that you will have to manually focus your lens and also set your aperture manually,
Steve Thomas
