Reply
New Contributor
Problems with T3 flash
My used EOS T3 flash works correctly in auto mode, but in av or tv mode I can't get the flash to pop-up. Am I doing something wrong?
Super Contributor
Re: Problems with T3 flash
Hey carpet1,
Those modes won't use flash unless you explicitly tell them too.  Because you're no longer in a fully-automatic mode, there's leeway for the camera to adjust other exposure settings to (try to) let in enough light / make the picture brighter.
If you want the flash to fire, press the Flash button before shooting and the flash should pop-up.  Its #3 here: http://www.imaging-resource.com/PRODS/T3/T3A2.HTM
New Contributor
The problem is when I press the button, the flash will not pop-up. When I press the button, the ISO setting screen appears. I have tried every setting I can think of. I have to go to automatic mode and push the picturentaking button halfway for it to pop-up
Super Contributor
[ Edited ]
FOUND IT!  Smiley Happy
Somehow one of your "Custom Functions" got set (from the previous owner, I'd assume).  From Page 77 of the user manual:
More details from Page 222:
Just hop into the menu, and change this back (to "0: Raise built-in flash"), and you should be good to go!
New Contributor
U the man! That is the problem and the solution. Thanks!
powered by Lithium
