Reply
Esteemed Contributor
Re: Pairing a canon EOS 1300D to a laptop computer
If you turned WiFi off in the camera, then I don't know. You either need to try another camera or another computer. USB cables can go bad, so I would try another one.
All my cameras work on all my computers, though I don't use EOS Utility.
Highlighted
Occasional Contributor
[ Edited ]
I encountered this same problem the first day I got my T6. The problem was the WiFi - I had to turn it off. It linked right up after I turned the WiFi off.
Not clear from the posts here if you tried this.
Thank's Kv, I will try another cable.
Kind regards
Trev B
Hi, Axepilot, I have tried so many things with this problem and I am reasonably sure I have tried what you are suggesting, However: I will check and see if the wi fi is on or off. Thank you for your input.
Kind regards
Trev B.
powered by Lithium
