05-09-2020 07:47 AM
I had been using a Rebel XS for many years and just recently bought a T7. I have a ProMaster 200ST-R speedlight that was working well on the XS.
When I put it on the T7 and have the same Manual settings, I get one flash off camera and then it doesn't flash again unless I cycle the power. On the XS, flash, flash, flash off camera for each push.
What could cause this behaviour? I am thinking something in the T7 is tweaked.
Thanks for any input
bandana
05-09-2020 10:46 AM
I have no experience with a ProMaster 200ST-R speedlight but I do know not all off brand flashes will work with all Canon cameras. This is probably your situation. Not compatible.
Personally I discourage the use of third party gear but especially third party flashes and batteries and battery grips. Some are OK but some are not.
05-09-2020 11:35 AM - edited 05-09-2020 11:37 AM
Bandana, if you still have your XS compare its hot shoe to the T7's. Notice anything missing on the T7?
05-10-2020 09:51 AM
Contact the vendor and see if they will be releasing a firmware update.
05-10-2020 07:38 PM
Thank you for the insight.
I see the center pin was removed from the hot shoe. I will call and check for a firmware update.
thanks
