04-30-2020 02:00 PM
Hi everyone,
I just got my second Rebel...T7i, and I used to be able to import pics from my Rebel XTi right to Photoshop Elements, and I'd like to do the same, as now I have Elements 2020. Before I attempt to try this, can it be done, or do I need to use the Canon software and USB cable? Thanks, Jan
04-30-2020 04:35 PM
05-03-2020 05:32 PM - edited 05-03-2020 05:32 PM
@Bluegypsy wrote:Hi everyone,
Hello Bluegypsy,
I do not have a T7i, but I do have an EOS SL2 and I also use Photoshop Elements 2020. I use a USB cable to connect my SL2 to my Windows 10 PC. PSE detects my SL2 with no problems and I can import photos from the SL2 directly into the PSE Organizer.
I have the Canon EOS Utility installed on my PC, but I do not use it to import photos into PSE.
04-30-2020 04:35 PM
You should be able to do it exactly the same.
05-02-2020 10:22 AM
"... as now I have Elements 2020."
You are sure you are in PSE 2020 and not an earlier version. I prefer USB far less issues.
Does the computer see the T7i?
If you have a Mac, that can be the problem if you updated your OS recently. Windows 10 should work without issues.
Hello Bluegypsy,
