Reply
New Contributor
Re: New T3 not saving photos to card
I am having the same problem. I formatted my card using the camera. Tried to write protected it, and then unwrite protected it. I am holding the button down longer and it still wasn't saving pictures. But I found I still was not holding it LONG enough. Very frustrating but the post was great. And the pictures are fabulous.
VIP
What button?
New Contributor
The shutter button, just hold it down until the camera is done.
VIP
And you think this is normal?  It is not.
 The shutter should fire in an instant of a second.  Unless you have a setting wrong.
Example, you have the mode dial on "B".  Go to your menus and 'clear all setting'.    Make sure the mode dial is on the green square.  Make sure your SD card is not write protected.  Try again.
New Contributor
It is on automatic (green square), and I don't see a menu item for clear all settings. It does click instantly but needs to 'reclick' again before the image is completely taken and saved to the card. The camera tells me when the card is write protected.
Reputable Contributor
[ Edited ]
Try putting the camera into P mode (which still gives you fully automatic exposures, but doesn't force you to use other camera settings).
I suspect the reason you're seeing an unacceptibly long delay before the shutter fires is that there is some sort of focus lock on... Maybe it's something that can be enabled or disabled in the menu, or that you are forced to use when in the "green box" mode. A focus lock will prevent the shutter from releasing until focus has been achieved and confirmed by the camera. How long it takes to achieve focus can vary from very little to a lot, depending upon many factors (focus mode, type of focus drive the lens is using, various user settings and techniques, light levels, subject contrast and probably more).
Turning off focus lock... or using an exposure setting that doesn't force you to use it... you should see the shutter trip almost instantly. Most DSLRs are much faster (have shorter "shutter lag") firing than many point-n-shoot cameras, although there is some difference among DSLR models, too.
Of course, the down side to not using focus lock is that you may see some shots that aren't perfectly in focus.
And there are good uses for a focus lock, such as "trap focus" with macro photography.
To get the best out of your camera, I suggest you go watch the three half hour videos about how Canon auto focus works, starting with this one. Learning how to use the AF system will help insure a high percentage of in-focus shots without using focus lock. Those videos are a few years old and pre-date the T3, but your camera has a fairly simple 9-point AF system, most similar to what the 5D Mark II in those videos uses (your camera does not have 6 hidden "Focus Assist" points, that the 5DII does). On your camera, the center point is a more sensitive "dual-axis/cross-type". All the others are "single axis". By pre-selecting only the center point, you will see the fastest possible peformance under the widest variety of conditions (weigh this against using multi-points/auto selected and that using the center point only tends to center the subject in all your shots).
Hope this helps!
Alan Myers
San Jose, Calif., USA
FLICKR & EXPOSUREMANAGER
VIP
"I don't see a menu item for clear all settings,,,"
It is in the last yellow wrench in your menus.  Second from the bottom in the list.  You maybe should spend some time with your manual.
New Contributor
Yes I am still learning my camera. I have looked at some you-tubes and everything helps. But until I was able to save my photos I could not even tell how to tell how my beginning attempts were going.
Esteemed Contributor
"It does click instantly but needs to 'reclick' again before the image is completely taken and saved to the card."
That sounds like the camera is set to Mirror Lock Up. to me.
VIP
Repeat!
You must reset the camera.
powered by Lithium
