Reply
New Contributor
Accepted Solution
My Cannon EOS 1300D/T6 won't connect to PC!
[ Edited ]
I've been looking for the past few days trying to connect my DSLR Camera to my PC and I still can't find a solution. I have installed all the necessary software in which Canon requires me to download for my specific model and I have also looked at the manual but nothing is working. No detection of the Canon DSLR in devices or anything. I thought it might be a driver problem but my drivers are updated to the latest version in which Canon recommends.
Any solutions I would highly appreciate it.
My OS Windows 10 Pro
VIP
Re: My Cannon EOS 1300D/T6 won't connect to PC!
You didn't say how you're trying to connect: via USB or Wi-Fi.  I am going to assume that you're trying to connect via USB, and that you're using the proper cable.  I will also assume that your Windows is up to date, and that you're turning on the camera after your connect the USB cable.
The very first connection might go kind of slowly, as the computer organizes the drivers it needs for the new device.  I've set up the EOS Utility on several Windows machines, and the initial connection was sluggish on all of them.  In fact, most of the time, the EOS Utility launcher would wake up and try to default to make a wireless connection, this despite being activated by a USB cable.
In the end, I almost always had to go into the Start Menu and launch the correct EOS Utility by hand.  Once I did that the first time, subsequent USB connection attempts would be recognized, and the Launcher would start the USB version of the EOS Utility.  In one case, though, the Utility Launcher did not wake up until I connected the USB with the camera already turned on, after which i could connect the cable with the more normal way, with the camera turned off.
New Contributor
I have found out what the problem was.
I needed to disable the WiFi/NFC on my camera and now it detects it straight away.
New Contributor
Thanks a lot Smiley Wink.. was struggling with this for the past two days.
New Contributor
hello   dear  where   you  got     softwhear    of  canon 1300d
New Contributor
That resolved the issue . ThanksSmiley Happy
New Contributor
THANKYOU!!!! I've been battling for 3 months to connect mine to my laptop! Wow you've taken a load off my shoulders. Thank you again.
New Contributor
Hi, I've been trying to do this but still can't connect it to a macbook and I used the USB cable; I'm sure it has the latest version and the camera do connects to my older macbook (2009), but now i have the mini one and it doesn't work;
If you know any solution I would highly appreciate it!
New Contributor
Thanks that did it! Canon's instructions leave much to be desired!
powered by Lithium
