02-11-2017 02:51 PM
Hello, I just bought canon 750D today and I have issues with the camera. I just clicked few pics and after that the i just get a "busy" message and it is not allowing me to take photos at all. What is the issue? It needs to be fixed. I am very disappointed. Can someone help me fix it?
02-11-2017 03:22 PM
@Punitha wrote:Hello, I just bought canon 750D today and I have issues with the camera. I just clicked few pics and after that the i just get a "busy" message and it is not allowing me to take photos at all. What is the issue? It needs to be fixed. I am very disappointed. Can someone help me fix it?
I'll try for a lucky guess: Is this camera an upgrade from a cell phone? Are you therefore using a micro-SD card via an adapter? Try a real SD card instead. Adapters often cause problems.
02-11-2017 04:04 PM
Make sure that your battery has been charged. There are a couple of reasons for a "busy" message that are described in the instruction manual. One of those reasons is related to the flash. You can get the "busy" message while the flash attempts to recharge itself, which is one reason why you need to fully charge the battery.
As previously advised, only use full size SD cards, and be sure to perform a LOW LEVEL FORMAT prior to using them. The Long Exposure Noise Reduction option can cause the "busy" message, too.
You can always contact Canon U.S. Support at 1-800-OK-CANON.
02-12-2017 04:55 AM - edited 02-12-2017 07:02 AM
750D has 5 fps and you can shoot 8 raw files at ISO 100 before the buffer is filled up, so 1½ second before you will see "busy".
The average write speed of your 750D is around 74 MB/s. Fastest write speed maybe 90 MB/s. Use a UHS-I card that claims 90 MB/s in write speed and the "busy" message will disappear faster.
02-12-2017 06:57 AM
Is this a permanent condition now or does it last for a few seconds and then camera works normally?
