10-21-2018 12:54 AM
I'm trying to download photos from my EOS Rebel T2i and I'm getting a busy signal on my camera and my camera isn't showing up as a device on my computer. I 'm running MacOS Mojave.
I've never had a problem before, but I did some agressive computer housekeeping and I must have deleted something important... like the EOS Utility. Yes. Oops. But I downloaded it again, the one for the T2i and a few other versions, and none of them worked.
What am I missing?!
Thanks!
03-17-2020 08:02 PM
Hello,
If your camera is not compatible with the OS on your computer, you can download photos or movies shot with the camera using a card slot on the computer or a commercially available card reader.
Windows 7 is used as an example, but the procedures are mostly the same if you use Windows Vista, Windows XP, or Mac OS X.
To download images, follow the instructions below.
1. Insert the memory card into the card slot on your computer or commercially available card reader. When using a card reader, make sure to connect the computer to the card reader before inserting the card into the reader.
2. The memory card data is loaded to the computer.
3. Images shot with the camera are saved in the memory card's [DCIM] folder with the following folder structure and file names.
4. Copy images in the folder to the computer. (As an example, the following screenshot shows that the DCIM folder is moved to the desktop of the computer by dragging.)
5. After the folder is copied, open the copied folder to check the images inside.
