02-20-2016 12:21 PM
I have updated the utility and my computer is still not recognizing the camera when it is plugged in via USB. When I go into System Information -- USB -- the camera is not there. How can I get the pictures onto my computer??
02-20-2016 03:48 PM
If system information shows nothing, it really sounds like a bad cable. Is this a laptop or a desktop?
02-20-2016 12:33 PM
What happens when you plug the camera in via USB and switch camera on? Any response from computer?
02-20-2016 12:41 PM
No response whatsoever.
02-20-2016 01:40 PM - edited 02-20-2016 03:30 PM
Did everything work before you updated to El Cap and or EOS Utility?
Is this the same cable you used when everything worked? Some cables are not data cables.
Does your computer have an SD card reader? Can you remove the card from the camera and plug it into the card reader.
Do you have a litte EOS Utiliy icon in the top hearder bar of the computer? If you click on it is it configured to "Start EOS Utility..."
Do you have an alternate camera you can test the camera on?
Sorry to shotgun, but since it works fine on my El Cap MacBook with T5i I know it can work.
02-20-2016 03:48 PM
02-20-2016 10:16 PM
It's a MacBook Air.
The camera worked on previous versions of OS X.
The icon shows up in the top bar.
It's a different cable, but one that has worked for other connections...
02-20-2016 10:17 PM
02-20-2016 10:19 PM
02-20-2016 10:22 PM
02-20-2016 10:24 PM
