10-14-2018 12:29 PM - edited 10-14-2018 12:31 PM
Help! I've been trying to do long exposure to get the bluring effect on running water. No matter what settings I enter into the manual mode all I get is pretty much a white image for anything longer than 0.5 seconds. I set the:
ISO to 100
Aperature to F32
Picture style: Standard
Ambience Priority: Auto
Auto Lighting: Standard
18-55mm lens
50-250mm lens
I've tried using a Hoya ND8 neutral density filter (helps a little but images are still way too washed out)
I've tried using a CPL filter at 90 degrees to the sun, no real improvement.
Any suggestions?
Can I stack two ND8 filters for a better picture, or will that create other problems?
10-22-2018 12:37 PM
I tried again at a different time of day, and used a variable ND filter. After several attempts adjusting the settings and the filter I was able to get a lot closer to what I wanted on a single shot. Still not perfect, but better. Anything longer than a 1 second shot still washed out pretty bad, and trying to compensate by turning the filter any farther resuled in uneven brightness. I understand that's the characteric of a variable ND filter to do that. I'm slowly getting there.
10-23-2018 09:51 AM
Yep... You're headed in the right direction now. And this scene has some completely different lighting than your first sample shot. The lighting, in general, is a lot more even here.
10-23-2018 08:04 PM - edited 10-23-2018 08:06 PM
@CraigPearson wrote:I tried again at a different time of day, and used a variable ND filter. After several attempts adjusting the settings and the filter I was able to get a lot closer to what I wanted on a single shot. Still not perfect, but better. Anything longer than a 1 second shot still washed out pretty bad, and trying to compensate by turning the filter any farther resuled in uneven brightness. I understand that's the characteric of a variable ND filter to do that. I'm slowly getting there.
I like this shot. You have captured a very good starting point.
Now it needs to [have just] a little post processing. Check the dynamic range of whites and blacks, level the horizon, and adjust the highlights and shadows. Finally, go ahead and tweak the contrast and colors however if you want. Done.
10-14-2018 01:18 PM
May need to combine photos then. Take a photo where you get the disired water effect, then apply layer masks for the backgrounds?
10-14-2018 01:37 PM
Ah, I see. The background is washed out, not the water streams. This is an HDR, High Dynamic Range, problem. I would bet that if you moved about, and took the shot without the bright background, then the problem will be minimized, if not eliminated.
If you are not familiar with HDR photography, you may want to explore it. The human eye can see a wider dynamic range of light than a camera sensor. DR is the difference between the brightest and darkest areas of a scene. Your shot is a textbook example of it, with a much brighter background compared to a darker foreground.
Had you exposed the shot for the background, then the foreground just might be nearly completely dark. When you expose for the foreground, then the bright background becomes overexposed and washed out. So, how do you solve this problem, and get correct exposures on the foreground and background in one image?
Basically, you “cheat.” You would need to take multiple exposures and then use software to combined them into one image. This is not as complicated as it might sound, because the software is usually totally automated. All you have to do is capture a good set of images for the software to work with. It usually takes a minimum of 3 photos, but you could use a larger sampling if you wanted.
10-14-2018 01:16 PM
Agree this does not make sense. I'm a novice, so I rely on using PhotoPils. I typically just snap a photo in auto mode, then use the app to determine the appropriate settings with a filter applied. Maybe that will help?
--Chris
10-14-2018 01:35 PM
"No matter what settings I enter into the manual mode all I get is pretty much a white image for anything longer than 0.5 seconds.
Any suggestions?"
You bet!
Well for this kind of shooting trial and error is the way to go and it looks like you have tried a lot. First before you 'try' again reset your T6 to factory. Menu, Tools , Clear all settings. Now set the T6 to record Raw only files. No jpg are needed for this. ISO to 100. You can set WB to average but it doesn't matter with Raw. Forget all the other settings. Off is best. Use M mode. You will need a tripod. Your exposures will be in the 10 sec range with the the Hoya ND8 neutral density filter installed. Aperture anywhere from f5.6 to f22. You need to block the view finder opening, too.
This should get you a usable image. Adjust settings as needed. Keep in mind with a 10 sec exposure, reducing to 5 sec or increasing to 20 sec is just one stop.
"Can I stack two ND8 filters for a better picture, or will that create other problems?"
You can but it is not needed or required. Don't use the polarizer either. My preference is to not use any of that or go to the trouble of all that and edit my shot in Photoshop. Works every time!
