12-06-2013 08:00 PM
My camera was working fine until my son decided to play with the settings.My screen is now blank and nothing happens with any button I press to see the screen. I can still take photos but can't change any settings, check photos I have taken or take photos seeing the main screen. I have a friends daughters 21st coming up and need my camera working.Please help.x
12-06-2013 10:19 PM
Does the Menu screen come up when you hit Menu? If you can get into the Menu, you can go to the Yellow tabs and find the command that says to return to default settings.
12-06-2013 10:28 PM
Also, here is your manual if you don't have it:
12-07-2013 07:04 PM
Thanks heaps for the manual, maybe that might shed some light. I have pushed all the buttons but still nothing, thanks heaps for your help.x
12-06-2013 11:23 PM
Typically this is the "info" button. It toggles through several optional things that can be displayed on the rear LCD... one of the options is to have the rear LCD blank. But you should still get a display if you press the menu or playback (image review) button.
Press the "info" button a few times (with camera powered up of course) until it returns to what you want displayed on the rear LCD.
You can adjust screen brightness, but generally not to the point that it's off completely (other than pressing the 'info' button as described above.) So I doubt he played with brightness.
12-07-2013 07:14 PM
Thanks heaps for your help but the screen is still blank. I just dont understand what he has done, have put the camera away for the day so I can take some deep breaths before giving it one last try to fix it before having to take it to a camera shop..I take it choping off my sons hands is not an option..lol..thanks again Deb
12-09-2013 07:20 PM
