07-06-2013 10:31 PM
I took my Sd card out today, and used it in my computer to download pics. When I try to reinsert the card it will not click into place. Anyone know why??
07-07-2013 02:01 AM - edited 07-10-2013 08:58 PM
Check your SD card (at the end with metal contacts) for any damage or debris. Seriously, use a magnifying glass if you have to. Sometimes damaged cards or cards with minor debris on them will not click into place properly.
07-09-2013 08:05 AM
Hi DeltaDawn!
Thanks for posting.
As suggested by fyigmo63, check to make sure the card is not damage. Also, try using another card in the camera. If multiple cards still do not work in the camera, it will need to be serviced.
To start the repair process, you'll need to complete a Repair Request on our website.
07-09-2013 09:22 PM
Make sure you're not putting the card in backwards.
When you insert the card, the side with the label should face the back of the camera. The side with the exposed gold contacts should face the front of the camera.
