06-26-2016 01:14 PM
The LCD panel indicates all is well (including the battery), I aim the camera and press halfway to focus and everything still seems to be fine, then when I press down the rest of the way to take the picture nothing happens. A look back at the LCD screen shows an empty battery (which flashes a few times) with nothing else on the screen. I have changed batteries and still get the same result.
06-27-2016 09:18 AM
Are the batteries making good contact? Is there anything on the contacts?
06-27-2016 07:49 PM
I have cleaned inside the battery compartment with a q-tip.
06-28-2016 05:33 AM
@traceydavidb wrote:I have cleaned inside the battery compartment with a q-tip.
Bad move. You do not want use something that can scratch, or leave residue behind, in this case lint and cotton fibers.
06-28-2016 05:40 AM
Thanks for the tip - will try something else!
